john kosmatka Posted February 6, 2005 Share Posted February 6, 2005 Hey guys, Im thinking on how I can set up the braking system on my Z, as Im putting in all new lines. Can I run a setup like this. A 50/50 split between the front left and front right, a 50/50 split between the right rear and left rear, and then run a willwood proportioning valve to adjust bias front to rear? TIA, any help would be appreciated. John Quote Link to comment Share on other sites More sharing options...
jt1 Posted February 7, 2005 Share Posted February 7, 2005 If you mean by 50/50 split coming off the master cylinder with a line to a tee and then a line to each caliper, for each end of the car, that's exactly what you do. The proportioning valve placed in the rear system will let your control the F/R split. John Quote Link to comment Share on other sites More sharing options...
