Question on Brake System
Hey guys, Im thinking on how I can set up the braking system on my Z, as Im putting in all new lines. Can I run a setup like this. A 50/50 split between the front left and front right, a 50/50 split between the right rear and left rear, and then run a willwood proportioning valve to adjust bias front to rear?
TIA, any help would be appreciated.
John
If you mean by 50/50 split coming off the master cylinder with a line to a tee and then a line to each caliper, for each end of the car, that's exactly what you do. The proportioning valve placed in the rear system will let your control the F/R split.
John
