Guest kellysguy Posted February 17, 2005 Share Posted February 17, 2005 Hmmmmmm, most interesting. Mine looks like it is longer but I can't see Nissan making two different pipes for the 300. Give me some casting numbers to compare. I don't know why mine won't fit, hhmmmmm. I don't like the 300 pipe; it's bigger but too restrictive. I don't dig that sharp edge on the short side radius of the outlet. I'd have to run a wedged shaped spacer to get the pipe angle correct......very strange.... very strange indeed!!!! A most unexspected turn of events..... good for you, now go put it on. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted February 17, 2005 Author Share Posted February 17, 2005 hey Kellysguy.. what does your casting say? Mine says "02P X30A" BUT i do have an automatic transmission... does it stick out further?? Cuz that would suck if I couldnt put it on.. Quote Link to comment Share on other sites More sharing options...
240ZinTN Posted February 17, 2005 Share Posted February 17, 2005 My downpipe looks the same as the one pictured in this post. The casting # is 212C 02P. I am using a 4spd out of a 78 280Z and it looks to be a little bulkier that the auto I had in there 8 months ago. The closest point to the downpipe is where the block flares out on the side to bolt up to the trannny. The auto I have has less of a flange so you shoud be ok. You don't need a spacer just bolt it up to the stock ex manifold and torque it down before you put your intake manifold back on. Good luck. Quote Link to comment Share on other sites More sharing options...
