Guest Murdoch Posted February 16, 2005 Share Posted February 16, 2005 hey, i just joined the forum so i'm sorry that this is probably a repost. will a chevy 396 SBC fit into a datsun with out having to chop or section the engine bay, and what if any clearence issues are there to be considered. Quote Link to comment Share on other sites More sharing options...
Guest Magnum Rockwilder Posted February 16, 2005 Share Posted February 16, 2005 Never heard of a 396 small block. Unless it's some new stroker/destroked setup, there's no such thing. There's a 350, 383 stroker, and 400. The GM 396 is a big block. Anyways, you can bolt any Chevy small block in with a JTR kit or a set of mounts from Hooker. You can also fit in just about any other engine you want, including a big block, with some ingenuity. Spend some time searching. Quote Link to comment Share on other sites More sharing options...
Pyro Posted February 16, 2005 Share Posted February 16, 2005 A small block will fit with no problem no matter what the internal dimensions of the engine are. A 396 cid sb can be made using a 400 crank that has been offset ground to hold small journal 327 rods. This gives another 0.070 stroke to the 3.760 stroke of the 400 for a total of 3.830. Then bore the block 0.060 over and there is the 396.5 cid sbc. The same thing can be done to a 350 crank for a 367.5 cid engine. Quote Link to comment Share on other sites More sharing options...
Turbo Meister Posted February 16, 2005 Share Posted February 16, 2005 Magnum Rockwilder said: Never heard of a 396 small block. Unless it's some new stroker/destroked setup "Speed-O-Motive" in So.Cal. sells a 396 SBC Racing Assembly. 350, .030, 3.875 Stroker crank. BTW when will your turbo SBC be running? Any progress pics? Hanns Quote Link to comment Share on other sites More sharing options...
