JTR P-N-P switch wiring?
Z2Z
Could some one please explain, or better yet, post a schematic of the wiring of the transmission side mounted P-N-P switch that JTR recommends in their books? It has 2 connectors.
The upper connector has 6 pins. I know that the 2 larger ones are the park neutral safety switch, 2 smaller ones with continuity in the reverse position are for the back up lights, but what are the other 2 meant for? I believe one might be a ground?
The lower connector has 4 pins, all the same size. What does it control and what pin position does what? I guess I am confused by the Chilton schematic diagrams. I haven't been able to figure it out. My drivetrain is a 95 Z28 LT1 and 4L60E.
  • 2 years later...
  • 5 weeks later...
Pin A - ?
Pin B - ?
Pin C - connect to switched power
Pin D - ground
Pin E - start terminal of ignition switch (one of the larger terminals)
Pin F - power out to back up lights
Pin G - to starter relay (one of the larger terminals)
According to Chilton the smaller plug is the transmission range switch that performs gear related functions for the PCM.
