Apexi S-AFC install.. I am getting close.. just need some help
As you guys may or may not know, I am attempting to install this Apexi SAFC to work on our older Z cars with the factory ECU.. and here is where I am stuck..
here is a thread with tons of info about it.. and stuff
http://forums.hybridz.org/showthread.php?t=87665
http://www.zcar.com/forums/read.php?f=1&i=558520&t=558520
Anyway.. I scanned the Apexi S-AFC manual's diagram, and wrote next to each connection what ECU PIN and what color the wire should be.
I also scanned the 1978 FSM for a diagram of what our car really has, compared to the overly simplified Apexi S-AFC diagram.
What I discovered is.. the Throttle Signal or TPS basically connects to 3 PINS on the ECU...
IDLE - Pin 2 and Pin 18 (black wire)
FULL THROTTLE - Pin 3 and Pin 18 (black wire)
and the Air Flow signal or AFM connects to 4 PINS.. *sigh*
Pin 6 and Pin 8 (black wire)
Pin 7 and Pin 8 (black wire)
Pin 8 and Pin 9 (black wire)
This is obviously a problem, because the Apexi S-AFC only has the TPS and AFM signal connected to one wire.. not 3 or 4 for each one!!!
Anyway.. can anyone give me a good idea on which wires I should connect this to.. to get it running??
