Guest DoTheDrew888 Posted April 4, 2005 Share Posted April 4, 2005 I was helping a friend take apart and rebuild an engine (L28) today. The previous owner said it had a "hot cam" in it. I was somewhat skeptical of this because I heard it second hand and the engine looked like it had never been torn apart before. But when we got the head off, I took a close look at the cam and it did look different than stock, well sort of different. The lobes on the cam seemed to be about the same shape as stock and the duration, from what I could tell, was the same. The difference was that the lift seemed higher than stock. When we went to set the head down the open valves made contact with the floor. This was on a P79 head by the way. The cam was not a reground because other than the larger lift it had (from what I can tell) stock specs. Has anyone ever heard of an aftermarket cam with specs similar to this? Also, the guy that sold it said the cam was made by Holley back in the 80's. I don't know if that is true or not. Quote Link to comment Share on other sites More sharing options...
katman Posted April 5, 2005 Share Posted April 5, 2005 And the specs are "the lift seems higher than stock" ???? Sorry, not much to go on. Any writing on the back of the cam? Quote Link to comment Share on other sites More sharing options...
Guest Magnum Rockwilder Posted April 5, 2005 Share Posted April 5, 2005 Measure a lobe at the highest point and narrowest point and subtract. The difference is the lift. Quote Link to comment Share on other sites More sharing options...
Guest DoTheDrew888 Posted April 6, 2005 Share Posted April 6, 2005 I seem to remember it having an "F" stamped on the end of it instead of the normal "K". Its not my engine but I will see if I can get some measurements if I go out there this weekend. Quote Link to comment Share on other sites More sharing options...
