Guest jjohart Posted April 15, 2005 Share Posted April 15, 2005 Hi...does anyone know how much in horsepower and or seat of pants improvement in power would a 370 CC SVO injector set up increase from stock turbo units. I mean, would it be a major power to dollar effect, provided use of modded afm and h.p fuel pump, adj. reg.,etc, or would it be a relatively mild increase with a fairly good penalty in fuel mileage/drop? Thanks John Quote Link to comment Share on other sites More sharing options...
GrayZee Posted April 15, 2005 Share Posted April 15, 2005 Assuming you can tune your upper powerband, stock turbo injectors should be good for 250hp (but that is pushing it) Any more and they will lean out therefore the need for bigger injectors. Unless you are planning on running above that HP range then I wouldn't bother. However I'm going by the idea of tuning the ecu rather than the afm. Tuning the afm isn't really that precise. Quote Link to comment Share on other sites More sharing options...
