Manifold Bolt Thread size
Guest rick458
Guest rick458
I found the Manifold bolt closest to the fire wall Broken in the head,
it is broken off 2 threads into the head and I plan on using a reverse drill
bit, and a tap to ensure good threads
SOOO exactly what thread size do I need to drill and tap it..
I thought it was a 1.25MM but that is a bit bigger than the Manifold bolts
and the Drill and tap set has no M#
The bolts are 8 X 1.25. To find the best bit to drill before you tap, insert different size bits into the holes of the studs you did remove and find the largest one that will fit into the hole. Be carefull and make sure that you drill exactly in the center of the broken stud. If it starts to go off to one side there is a chance you will damage the treads on the head. Stop and use a smaller bit to prevent this.
