TPI finally works with small cap dizzy
mobythevan
After a few weeks of problems I think we finally have MSnS_Extra controlling spark using the small cap TPI dizzy with 8 pin HEI module that is inside of it. With help from James and Lance on the megasquirt site a hardware triggering problem was found. Now the MSnS code controls the module so that it uses bypass mode for cranking (which gives a real fast fire up) and then switches back to ECU controlled timing. Dwell control also seems to be working good and is user configurable for cranking, running and minimum discharge. I am using MSnS_Extra024n code for this setup.
