Guest 007fastZ Posted May 10, 2005 Share Posted May 10, 2005 Ok i have a 355 that has been balanced with an forged eagle crank, eagle rods, and je pistons. My question is what size damper should i get, i know it has to be 7.25 and under, and does it need to be external or internally balanced and what does that mean. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
jt1 Posted May 10, 2005 Share Posted May 10, 2005 If your rotating assembly was internally balanced, 99% of 350's are but you should ask whoever did the balance job, then you want a neutral balanced damper and flywheel. Neutral balanced damper and flywheels are sometimes (incorrectly) referred to as internally balanced. "External balance" means the damper and flywheel have weights on them to help balance the rotating assembly. Normally this is only done on 400 and 454 factory cranks, or to keep from adding mallory to a crank. As you mentioned, 7.25" or less. I use a 6 1/4" Fluidamper. John Quote Link to comment Share on other sites More sharing options...
Guest 007fastZ Posted May 11, 2005 Share Posted May 11, 2005 jt1 So if my block was at the machine shop and balanced only with the crank, it has been internally balanced, but if you are talking about externally balanced then it has to do with the crank, the balancer, and the flywheel correct? So i need to order an internally balanced fluid damper? Also does size matter to how high you can rev, is a 6 1/4 better than a 7.25? And also i see alot of fluid damper with all kinds of prices, in jegs and summit i see 2, 3, and 4 hundred dollar price tags, but searching on ebay i found ones for $100, as this one shown http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7972948222&category=33616&sspagename=WDVW Thanks for all the info. Chris Quote Link to comment Share on other sites More sharing options...
jt1 Posted May 11, 2005 Share Posted May 11, 2005 So if my block was at the machine shop and balanced only with the crank, it has been internally balanced, but if you are talking about externally balanced then it has to do with the crank, the balancer, and the flywheel correct? Yes. So i need to order an internally balanced fluid damper? Yes. Also does size matter to how high you can rev, is a 6 1/4 better than a 7.25? The difference, so far as to how quick the engine will rev, is so small that for all practical purposes it's insignificant. The main reason I got a 6 1/4 is to give plenty of clearance to the steering rack. And also i see alot of fluid damper with all kinds of prices, in jegs and summit i see 2, 3, and 4 hundred dollar price tags, You pretty much get what you pay for, although there are bargains to be had. That one appears to be a chinese copy of a Fluidamper, but it does say it's SFI certified. I wouldn't run one that's not SFI certified. John Quote Link to comment Share on other sites More sharing options...
Guest 007fastZ Posted May 11, 2005 Share Posted May 11, 2005 Thanks for all the good info Chris Quote Link to comment Share on other sites More sharing options...
Psykovertible Posted May 14, 2005 Share Posted May 14, 2005 I have an sfi rated fluid style damper that i would let go for $100. paid about $150 for it and its new in box. never used it cause it is for internal motor and i ended up building a 400 and cant use it. shipping would be about 10-15 range anywhere in the states. not sure hoe that compares with current pricing. i have some pics if interested Quote Link to comment Share on other sites More sharing options...
Guest 007fastZ Posted May 17, 2005 Share Posted May 17, 2005 what size and brand. It is new correct? If you could send pics to my email winter5573@yahoo.com that would be great. Thanks Quote Link to comment Share on other sites More sharing options...
Psykovertible Posted May 17, 2005 Share Posted May 17, 2005 sorry for delay. just saw you post. part sold here in town yesterday. it was a 6.75" chrome one. send me an email and I will help you track one down if you would like. Ebay is teh most likely resource I would use. I bet I could score another within a couple weeks for a similar price. Quote Link to comment Share on other sites More sharing options...
