randy 77zt Posted May 13, 2005 Share Posted May 13, 2005 i was reading on ms forums-from what i read it said to use version 225b358.but since i suck with software(i am much better with a hammer)i downloaded 390,366,462,417,358 looking for correct screens for programming ignition.found out files in the downloads-they have to be extracted & filed correctly.before i work on this more i would like to know which version is most trouble free .as far as getting it set up i made a copy of the webpage but i can get the it guy from across the street help me set it up-he owes me alot of favors for fixing his boat trailer wiring.i did manage to get a cherry hall effect sensor flashing with a pull up resistor and a 9 volt battery and a led.i am not recycling any old z stuff on my install-even wiring from battery will be new to supply ms.will be using msd6a. Quote Link to comment Share on other sites More sharing options...
dmanzo57 Posted May 13, 2005 Share Posted May 13, 2005 Randy, It depends on which version of code you are using. Read the following post... http://www.msefi.com/viewtopic.php?t=6086&sid=9a1c53692a733dc9aa150c55fdd1a834 I think they just declared 024s9 as stable, which would use Megatune 2.25b417. I've been running 024s7. Don Quote Link to comment Share on other sites More sharing options...
