'77 5 Speed Question
Toysport
Use the flywheel that you have with the clutch that you have and the throwout bearing collar that corresponds to the transmission you are using. That has always worked in my experience, but always do as much checking while you are doing the swap before installing parts that don't work together. You are ok with your 76 flywheel and clutch.
-Oliver
