mustard-z Posted May 20, 2005 Share Posted May 20, 2005 We've been having problems with our charging system in our 280z FP autox car. Seems the alternator gave out and we looked for a replacement. We ended up using a GM 1 wire alternator. I worked out great...we ended up using the stock lower mount and cutting the front half off and addind a plate that bolts to the front of the engine and installing a 4" bolt to thru bolt the whole thing together. It is the same size as the stocker only needs one wire connected to the battery for charging and mild mods to fit it in. Its rated to 60amps too. I can take pix if anyone is interested. Aren Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted May 22, 2005 Share Posted May 22, 2005 If you need a larger amp alt, you can order an 80 or a 105 kit from JcWhitney for 20 bux or so, I've ordered all mine thru them and never had a problem. I put the GM on everything I run. Quote Link to comment Share on other sites More sharing options...
