Guest disassembled Posted May 21, 2005 Share Posted May 21, 2005 Tomorrow i plan to do an intake gasket on my 82 L28T. I've already replaced the gasket once and i probably did something wrong last time. This is what i did last time: Tore everything down cleaned off head surface with gasket remover and razor blade covered gasket in copper sealer spray let gasket sit for a few minutes reattached intake tightened to spec reattached exhaust mani tightened to spec reattached turbo from the minute i started the car up i had an exhuast leak pre turbine but i was too exhuasted to tear it down again (especially when working out in the open) Do you guys have any tips? Should i leave the turbo off until i see that i don't have any exhaust leaks? Should i torque everything down more than spec? I am selling this car soon and i just want it to be running as good as possible. If anyone is interested i will let it go for $1200. Greg Quote Link to comment Share on other sites More sharing options...
Guest 73Turbo240z Posted May 21, 2005 Share Posted May 21, 2005 are you sure your manifold decking is true still? not warped in any way? Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted May 21, 2005 Share Posted May 21, 2005 the exhaust manifold warps .check it with a straight edge.it can be trued at a machine shop -usually about $30 or $40.put the exhaust manifold on first then the intake.i use anti-sieze on the exhaust bolts.alot of times the studs on the ends of the cylinder heads break.soak parts with pentrating oil thr day before working on. Quote Link to comment Share on other sites More sharing options...
Guest disassembled Posted May 23, 2005 Share Posted May 23, 2005 Well i finally finished the intake/exhaust gasket today after spending a lot of time yesterday putting on my new motor mounts. I also replaced the turbo gasket. What a difference good gaskets make as i now have a decent running car. Before my car would take forever to make boost now it's at full boost by 2500 and holds it until redline. Next i have to look at my timing since it seems to lose a lot of power up top. I still think i should sell the car though because two projects at once is not so nice on the wallet. Greg Quote Link to comment Share on other sites More sharing options...
