EZ-E Posted June 23, 2005 Author Share Posted June 23, 2005 I welded the whole thing together just so I could get it back on the road, and I will eventually cut and replace as needed to finish it up which shouldnt be to hard now that its all in place. I will probably onlyl use two couplings. one down off from the dp and another at that bottom side of the crossmember. I just wish I could weld better but without trying you never know what you can do or how good or bad you can do it. So its just practice makes perfect. Quote Link to comment Share on other sites More sharing options...
VinhZXT Posted June 23, 2005 Share Posted June 23, 2005 EZ-E, It's not easy to take the first step. I give you a lot of credit for that. I 've been there so I know. I had to learn many things by just experimenting and the results were not pretty. Every thing takes times and practice. Good luck on your next project.. Quote Link to comment Share on other sites More sharing options...
