Guest lovemonkeye Posted June 3, 2005 Share Posted June 3, 2005 i have a 283 sbc bored .30 over with 71 corvette heads and about a 9:1 comp ratio. my question is what kind of carberator should i be getting for it, i understand that stock 283's came with 2 barrels but since this ones a little pumped im wondering if i should get it a 4 barrel. thanks for any information you guys can give me Quote Link to comment Share on other sites More sharing options...
jbk240z Posted June 3, 2005 Share Posted June 3, 2005 HI, If it were me, I would use a 650 holley d.p. I think it would work great on a high-winding 283. Good Luck! Quote Link to comment Share on other sites More sharing options...
Guest tony78_280z Posted June 3, 2005 Share Posted June 3, 2005 CFM = ((CUI *RPMS) /3456) * VE I dunno what a 283 bored over ends up being in CUI. But a stock 283 would want about 400cfm at most. [ie. 393.05 = ((283*6000)/3456) *.80 ] You've probably got more than 80% VE with those heads and being bored out a bit... (begin speculation now)... I'd shoot for about 500cfm. Definatly not more than 600cfm. Be sure you get a good manual for the carb you select to be certain it is set up properly. Quote Link to comment Share on other sites More sharing options...
