Questions For Sr240z And Vildini...
Guest PROJECTRB240SX
I Purchased A Sr 240z From Matt B. On Saturday And I Had A Few Questions About It.
1.) Are The Motor And Trans Mounts Stock Silvia/240sx Ones?
2.) Do The Ports On The Top Of The Surge Tank Differ? I.e. One Has A Tube That Goes To The Bottom Of The Tank, Etc.
3.) Do The Reverse Lights Work? I Tried Swapping Bulbs And They Still Don't Come On.
4.) Was The Ecu Altered At All?
That Should Be It Until I Run Into More Issues....
Thanks For Your Time,
Christian
Proud New Owner Of One Of Your Beautiful Products.
Motor mount and trans insulators are stock 240z.
Take a pic and email if you can.
Check the plug on the tranny that connects to the reverse light, if not then it got disconnected.
ECU is stock sr20det.
Clutch line is also from a 240z.
Yes yes I did..... I hung door to door with a c5 till 130mph and I raced my buddies 911 from a roll and from a stop. I can beat the porsche from a stop but I can only hang with it if its from a roll. Its a fast little Car!!!! Way better than the v8 car I had.
I have one more question: Do you know if they make solid or polyurethane 240z motor and trans mounts? I've been looking at a few sites and have yet to run across any.
