VG30DE and VG30DETT tranny
Guest Kaiyin
Guest Kaiyin
I was just wondering if the tranny used on the VG30DE and VG30DETT are the same. I was told that the trannies and diffs were different and if I were to swap that I'd need those parts.
The only differences between them are the place where the starter bolts up to. There's a bit more material on the TT tranny since the clutch/flywheel setup is 250 mm while the N/A clutch/flywheel setup is 240 mm.
I believe they also say the internals of these trannies are the same as the earlier GT-R's. Basically, the Z32 trannies can handle a lot of power (the manual trannies that is).
