Front Brake Options
Ive re-posted this as it probably should be in a seperate post,
This is what i have planned for the front brakes with my new hubs,
Option 1,
Uses a Mitsubishi 3000GT rotor, which is 314mm by 30mm, Its 45.5mm in height and has a 5 by 114.3 PCD, i will have to enlargen the centre hole from 69mm to 71.5mm, i will use a R32/Z32 4-Spot Sumitono Caliper, i choose this rotor cause its $89AUD/side slotted and its the right thickness for the R32/Z32 Caliper
http://album.hybridz.org/showphoto....&cat=500&page=1
Option 2,
Uses an R32 GTR V-Spec Rotor, which is 324mm by 30mm, its 53.75mm in overall height and has a 5 by 114.3 PCD, i have to enlargen the centre hole from 68mm to 71.5mm and once again i will use the Sumitono's,
These Rotors aint cheap though, DBA only sell them in 4000 series, so they will be around the $200AUD/side mark,
At the moment Im trying to decide whether to mount the caliper bracket on the inside or outside of the original Zed caliper mounting ears,
Im thinking it would probably be easier to mount them on the inside, Because if i mounted the bracket on the outside of the original Caliper Mounting ears i would probably have to thread the bracket as i dont think i would have space to put a nut on the bolt end,
What you guys think???
