Guest cingham Posted August 4, 2005 Share Posted August 4, 2005 Hi all new to the fourm, long time reader on Torque central and someone introduced me over to this site when i popped the question of a LS1 in a 300zx. Glad they did looks like a lot of information to be obtained here. I was reading an old post about a step by step how to on the 300zx LS/LT conversion. Only problem is that the post was from 2 years ago and the person posting I don't think has been on this board for a lon time. I see a lot of 240's, and have almost gone through every 300zx LT/LS1 post. Does anyone know if this instruction manual is still in existance? or lost over the last 600 days? Another question i have about this swap is where is the drive line from? modified 300zx shorten and balanced? I look forward to reading more here....god knows this is gonna be cheaper then a 93 RX-7 Quote Link to comment Share on other sites More sharing options...
Guest tigpro Posted August 5, 2005 Share Posted August 5, 2005 I have a 86 300zx and i had the same problem. but i can tell you a little about my swap to 350/700r4, on mine i had to cut the tunnel on the pass side to allow the tranny lines and servo cover to fit.then i had to cut the oilpan so the crossmember would work in the stock location. other than that it is straight forward. i made my engine mounts with 5/16 mild steel plate to fit clamshell type mounts and then for the bottomside i made it with 1-1/2 square tubing welded to the crossmember. good luck. Quote Link to comment Share on other sites More sharing options...
Guest cingham Posted August 5, 2005 Share Posted August 5, 2005 oh iam also talking about hte z32 not the 31. Quote Link to comment Share on other sites More sharing options...
