Phyxius Posted August 14, 2005 Share Posted August 14, 2005 It seems that what I thought was an injector problem may turn out to be a computer problem. Yesterday, the injectors were staying open after the engine stopped (key still on), flooding the motor. Today, with the motor off (key still on), the computer continously sends the spark signal at about 3 times a second. When i try to hook my laptop up to it in the car, it won't connect. I can hook the ms up to the stim board, and I can connect to it, and it seems to operate normally. My only thought is that there is something wrong with the relay board and associated wiring, but i can't find anything wrong... any thoughts or ideas? Quote Link to comment Share on other sites More sharing options...
mobythevan Posted August 15, 2005 Share Posted August 15, 2005 I hate that kind of stuff. My friend just found yesterday that his MAP sensor tubing was conducting electricity and shorting out some of the circuit to the MS case. His also failed on the stim board which makes it easier to troubleshoot. Sounds like the input to the tach trigger may be floating or miswired causing the continual triggers? Quote Link to comment Share on other sites More sharing options...
Phyxius Posted August 15, 2005 Author Share Posted August 15, 2005 That wouldn't explain the fact that it won't connect to my laptop in the car. I don't know what to think...all i know is that it's way too hot outside during the day to mess with it...lol Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted August 15, 2005 Share Posted August 15, 2005 Something might be grounded causing a fault with the serial communications and other workings of MS. You probably have to check the sensors and wires individually since it checks out on the stim. Did you make your own harness? Check grommets or places where the wires might have gotten pinched or stretched. Good luck, Mario Quote Link to comment Share on other sites More sharing options...
Phyxius Posted August 15, 2005 Author Share Posted August 15, 2005 should I be able to make rpm's go all the way to 0 with the stim board? I can only get it to go down to 87... Quote Link to comment Share on other sites More sharing options...
