Guest bigbadzcar99 Posted August 15, 2005 Share Posted August 15, 2005 I have a couple questions about my turbo swap. I have a 77 Z using 82 turbo electronics. I am using the 77 rotating assy and block, the top end is a P90 head, pre smog intake, 60 mm t/b. I just received my 82 wiring harness and had a couple questions about the electronics. First off, my TPS, can I use the 77 TPS, the original harness has 3 connectors and the 82 only has 2, don’t know if it will work. Second, Knock sensor/crank angle sensor... I am planning on using crane Hi-6R ignition, I already have an XR3000 and PS91 coil. I would like to keep the original dizzy if possible, as the XR3000 wasen't cheep. And last, what relays will I need from an 82 to make all this work? Are there some that can swap? I found a few plugs on the new harness I am unfamiliar with, and would like to know what all you other guys with swaps had to get ahold of. I have a Haynes for a 82 on the way, and that should help me out allot, but a list and answers would be nice. I just don’t want to get the Crane system to find that I cant make it work without the crank sensor or something. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
