More MS problems
Phyxius
hey guys...
For some reason, my MS has stopped sending the spark command all together...when installed in the car...
It will do fine on the stim board...so I'm thinking maybe something is wrong with the trigger signal?
Will the fidle light in megatune turn on if the coil isnt firing but the trigger signal is being sent?
When the light stays on, it will send a the signal, but it will only fire once. Maybe the short is in the spark output and you might have damaged some components.
When I hooked mine up wrong and killed the spark output, the led would still flash, but it wouldn't send it out. I confirmed this by testing the HEI module, which turned out to be good.
Maybe Tony D or Moby will chime in....
Mario
