racerx260 Posted August 20, 2005 Share Posted August 20, 2005 I Have A Stock 83 Turbo Motor And Ecu In A 260.cranks And Idles Fine , Runs On 10psi Of Boost Fine. I Have Threded The Waste Gate Rod To Get 10 Psi.my Drive Ability Issue Is When In Trafic And Trying To Be Easy And Stay Off Boost The Engine Seems To Surge On And Off Like The Fuel Is Running Out.it Is Suttle But Noticeable.if I Ease It Up In Rpm And Start To Build Boost It Stops Surgeing And Runs Smoothly.this Is Only At Low Speeds In First Or Second Below 2700 Rpm.when Cruseing At 35 Mph And Up There Are No Issues.any Ideas? Wow Me With Your Wisdom. Quote Link to comment Share on other sites More sharing options...
