TheNeedForZ Posted September 18, 2005 Share Posted September 18, 2005 Hi, I used the search function but apparently the search engine doesn't like the term "2+2" so I can't get results. I am planning a turbo swap into a 280Z and there's a guy selling his 280ZX turbo 2+2. I am wondering if there's any difference between a ZXT swap and a ZXT 2+2 swap. Also, the 2+2 is automatic, but I will use the original 4-speed MT on my 280Z. Will the automatic ZXT 2+2 parts drop in like the ZXT parts? Any difference? Thanks Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 18, 2005 Share Posted September 18, 2005 none.. engine is the same.. mike Quote Link to comment Share on other sites More sharing options...
Metro Posted September 18, 2005 Share Posted September 18, 2005 Also' date=' the 2+2 is automatic, but I will use the original 4-speed MT on my 280Z. Thanks[/quote'] Just make sure you take the spacer off the crank before you put your M/T flywheel on, otherwise the starter won't engage. You should also consider getting a 240mm flywheel and clutch from a turbo car, 2+2, or mid 80's nissan truck, if you haven't already. Quote Link to comment Share on other sites More sharing options...
