Zraced... Posted September 28, 2005 Author Share Posted September 28, 2005 It has a yellow light that will flash for the RPM signal and the tach readout on the software does work. So I think the CAS is working...maybe just to much fuel with the 555cc Nismo injectors perhaps...not sure on how to reduce the duty cycle of the injectors yet. Quote Link to comment Share on other sites More sharing options...
Zraced... Posted September 29, 2005 Author Share Posted September 29, 2005 Well I found that the number five coil is no good as it started to heat up and burn...this can add to my troubles...I put the 300ZX CAS disk into my 280zx sensor. I removed the injectors and fuel rail as a whole and turned the motor over to see if the injectors were injecting. They work fine with no trouble...I will now turn my attention to the CAS, which seems to be my trouble. The 300ZX disk seems to work with the 280ZX sensor that I have. Once I get a new coil I will fire the motor up once again. I have my computer setting saved to a text file if anyone wants to look at it and see if there are any problems. Give me your email and I'll send it. Thanks for the input so far everyone, -Cole Quote Link to comment Share on other sites More sharing options...
Zraced... Posted October 5, 2005 Author Share Posted October 5, 2005 ON3GO do you remember if your CAS needed a resistor wired into the sensors lines? I just want to double check my setup before I get my new coil. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted October 5, 2005 Share Posted October 5, 2005 ill check tomorrow. i dont think so though. ill deff check tomorrow, mike Quote Link to comment Share on other sites More sharing options...
Zraced... Posted November 19, 2005 Author Share Posted November 19, 2005 I finally got my motor to run and man is it running good... the 555cc injectors were dumping to much fuel into the cylinders causing the motor to choke. I found the right setting and now the motor runs strong. If anyone needs help with an LT12 w/6coil setup let me know and i'll get the settings to you. Now I can get to tuning!!! Quote Link to comment Share on other sites More sharing options...
