VK engine matchup
Guest check_engine
Guest check_engine
I found this at nissanperformancemag.com. I hope they don't mind the reprint. Here is the original link, http://www.nissanperformancemag.com/may02/infinitiengine.php. Sorry about the length, but I can't get it to stay in chart form. Can a mod help out?
Infiniti Indy
35A IRL
2002
Infiniti Q45
2002
Infiniti Pro Series
Designation:
VRH35ADE/612E
VK45DE
VK45/610A
Type:
DOHC 32-Valve V8 with aluminum-alloy block and heads with molybdenum coated pistons
Cylinder Angle:
90-degree
90-degree
90-degree
Displacement:
3.5-liter
4.5-liter
3.5-liter
Horsepower:
650 @ 10,700 rpm
340 hp @ 6,400 rpm
450 hp @8100 rpm
Torque:
320 @ 10,400 rpm
333 ft-lbs @ 4,000 rpm
304 ft-lbs @ 6750 rpm
Bore x Stroke:
93 x 64.39 mm
93 x 82.7 mm
93 x 64.39 mm
Bore Spacing:
112 mm
112 mm
112 mm
Compression Ratio:
13.8:1
10.5:1
10.5:1
Induction System:
Sequential multi-point fuel injection
Valvetrain
DOHC 4-valves-per-cylinder, titanium valves
DOHC 4-valves-per-cylinder, titanium valves with variable valve timing control.
Crankshaft:
180 degree-Billet Steel
90 degree-Forged Steel
90 degree-Billet Steel
Connecting Rods:
Machined Alloy Steel
Forged Steel
Lubrication System:
Multi-stage dry sump
Wet sump w/trochoid gear
Oil Capacity:
12.0 quarts
6.0 quarts
6.0 quarts
Max. Engine Speed:
10,700 rpm
6,900 rpm
8,200 rpm
Fuel:
Methanol
Premium Unleaded
Premium Unleaded
Top Speed:
225+ mph
150 mph (electronically limited)
200+ mph
