Guest check_engine Posted October 13, 2005 Share Posted October 13, 2005 Found this info on Nissan rods, add whatever you find. Maybe someone could add some bore measurments for these blocks? VQ30; Rod Length (center dist): 147.65 Rod Stroke Ratio: 2.014 (73.3mm stroke) Pin dia. w/bushing: 22.0 Rod big end dia. : 48.0 VQ35; Rod Length (center dist): 144.2 Rod Stroke Ratio: 1.771 (81.4mm stroke) Pin dia. w/bushing: 22.0 Rod big end dia. : 55.0 VQ40; Rod Length (center dist): 166.87 Rod Stroke Ratio: 1.813 (92mm stroke) Pin dia. w/bushing: 22.0 Rod big end dia. : 57.0 VG30/VG33/VE30; Rod Length (center dist): 154.15 Rod Stroke Ratio: 1.857 (83mm stroke) Pin dia. w/bushing: 20.994 Rod big end dia. : 53.0 KA24; Rod Length (center dist): 165.0 Rod Stroke Ratio: 1.719 (96mm stroke) Pin dia. w/bushing: 21.0 Rod big end dia. : 53.0 QR25; Rod Length (center dist): 143.0 Rod Stroke Ratio: 1.43 (100mm stroke) Pin dia. w/bushing: 20.0 Rod big end dia. : 48.0 VH45/VK45; Rod Length (center dist): 147.0 Rod Stroke Ratio: 1.778 (82.7mm stroke) Pin dia. w/bushing: 22.0 Rod big end dia. : 55.0 VH41; Rod Length (center dist): 147.0 Rod Stroke Ratio: 1.934 (76mm stroke) Pin dia. w/bushing: 22.0 Rod big end dia. : 55.0 VK56; Rod Length (center dist): 154.5 Rod Stroke Ratio: 1.679 (92mm stroke) Pin dia. w/bushing: 22.0 Rod big end dia. : 57.0 SR20; Rod Length (center dist): 136.3 Rod Stroke Ratio: 1.585 (86mm stroke) Pin dia. w/bushing: 22.0 Rod big end dia. : 51.0 GA16/QG18: Rod Length (center dist): 140.5 Rod Stroke Ratio: 1.597 (88mm stroke) Pin dia. w/bushing: 19.0 Rod big end dia. : 43.0 Quote Link to comment Share on other sites More sharing options...
