Camshaft Tech Lines
I finally got a chance to catch up on my reading for the last few weeks of HybridZ & noticed a few threads @ camshafts: Hydraulic -vs- Mechanical roller. I have a book that lists mosts Tech lines & thought it would be helpful.
CAMS
1)Cam Motion.....504.926.6110
2)Chet Herbert Cams...714.7501211
3)Comp Cams......800.999.0853 or 901.795.2400
4)Crane Cams.....904.258.6174
5)Crower Cams....619.422.1191
6)Custom Speed(Harlons Sharp)..440.238.3260
7)Edelbrock Corp...800.416.8628
8)Engle Cams.....310.450.0806
9)Erson/Mr Gasket...775.882.1622
10)Ferrea Racing.888.733.2505 or 954.733.2505
11)Isky Racing Cams..323.770.0930
12)Lunati........901.365.0950
13)Manly.........732.905.3366
14)Miloden.......818.407.1211
15)Pete Jackson Gear Drives..323.849.2622
16)Powerhouse Products...800.USA-RACE
17)Schneider Racing Cams...619.297.0227
18)Ultradyne Racing Cams...601.349.4447
19)Wolverine/Blue Racer...800.248.0134
Valves,Gears,Push Rods, Timing Belts & Bolts
1)ARP (Bolts & Stuff)......805.278.7223
2)Clevite 77...............313.663.6400
3)Cloyes Gear Products.....501.963.2105
4)Eastwood Co.(Shop Tools).610.640.1450
5)Eric Thompsn Push Rods...760.742.1113
6)Fel-Pro..................708.674.7700
7)Fluidampr................716.895.8000
8)Jesel.(Timing Gears ect).732.901.1800
9)K-Motion Valve Springs...800.428.7891
10)Mr Gasket...............775.882.4622
11)Pete Jackson Gear Drives323.849.2622
12)SI Valves...............805.582.0085
Pistons/Rings
1)Federal Mogul............248.354.9445
2)JE Pistons...............714.898.9763
3)Speed Pro/Sealed Pwr.....616.724.5011
4)Total Seal Gaples Rings..602.678.4977
5)Weisco Pistons...........800.321.1364
Ignition Systems
1)Mallory Ignition.........702.882.6600
2)MSD Ignitions............915.857.5200
3)Jacobs Electronic........800.627.8800
Headers/Exhaust
1)Hooker...................909.983.5871
2)Hedman Mfg...............310.839.7581
3)Flowmaster...............800.544.4761
Auto Performance:By Mfg's Name
1)Chevy Perf..See Local Dealer Parts Dept
2)Ford Motorsports/SVO.....810.468.1356
3)Ford Perf.Solutions......714.773.9027
4)Mopar Perf...............248.853.7290
Cylinder Heads/Fuel/Induction
1)Brodix Cyl.Heads.........501.394.1075
2)Barry Grant Fuel Sys's...706.864.8544
4)Edelbrock................800.416.8628
5)Fuel Curve Engineering...704.894.3511
6)Holley Carb.Div..........313.497.4000
7)the Nitrous Works........706.864.7009
8)Trick Flow...............216.630.1555
9)TWM Inductions...........805.967.9478
10)Weiand Auto Ind.........901.396.5782
Transmissions/Clutches
1)B&M Auto.................818.882.6422
2)Centerforce Clutch.......714.898.4477
3)Trans-Dapt...............310.921.0404
Performance Warehouses & Perf.Shops
1)Brzezinski Racing Prod...414.246.8577
2)California Dis.Wrhouse...310.423.4346
3)the Carburetor Shop......909.947.9722
4)G&L Coatings.............619.743.0224
5)H/O Racing...............888.703.4477
6)K&N Engineering..........909.684.9762
7)Moroso...................203.453.6571
8)Norwack & Co.............714.282.7996
9)Perf.Auto.Wrhouse (PAW)..818.998.6000
10)RHS Perf.Eng's..........901.794.2830
11)Schaver Specialty.......310.370.6941
12)SD Performance..........714.997.3777
13)Summers Bro's Inc.......714.986.2041
14)Summit Racing...........216.630.0200
15)T&D Machine.............775.884.2292
16)Tilton Engineering......805.688.2353
17)VHT.....................602.991.8002
18)Warrior Racing Prod.....734.728.8600
19)Westech Perf.Group......909.685.4767
Personal Name Racing Shops
1)Bennet Racing..................205.486.5520
2)Bill Mitchl Hardcore Racing....516.737.0372
3)Childs & Albert................805.295.1900
4)Cottrell Racing Eng's..........612.448.5330
5)Dick Landy Ind.................818.341.4143
6)Dutweiler Engineering..........805.659.3648
7)Hughes Engines.................309.745.9558
8)Jim Butler Racing..............931.762.4596
9)Joe Sherman Racing Eng's.......714.542.0515
10)Klein Engines.................602.967.5990
11)McFarland Inc.................213.533.6100
12)Nally/Moody Racing............404.368.0873
13)Lingenfelter Perf.Eng's.......219.724.2552
Sorry the list is so incomplete & this is all I could come up with; HEY!!! If theses guys cant help you then you cant be helped!
Remember, berfore you call (so as not to waste their time: Yes, you are the customer yet they cant help you if you dont know what it is you want) make sure you have an idea of a few things:
1) Weight of Car
2) Eng/Trans Compbo
3) HP/Torque Expectations
4) Rear Gears & Tires
5) Racing or Street/Strip
This is what I do on a Sick Day w/the Flu
Hope This Helps
[This message has been edited by Kevin Shasteen (edited January 30, 2001).]
