tonycharger72 Posted October 31, 2005 Share Posted October 31, 2005 I wasnt quite sure where to ask this but, Im in the process of sorting out my wiring harness and was wondering what i was going to do about the gauges, i think i've got the speedo and tacho worked out but still a little bit unsure about what to do with the Oil pressure gauge and the Water temperature gauge, I've pulled the sender units of an old L-26 i have lying around and was thinking i might try and screw them into the 2jz block somehow, Anybody who has done a 1jz or 2jz conversion end up using the stock Datto gauges??? if so, where did you put the Oil & Temp sender units??? Quote Link to comment Share on other sites More sharing options...
