Guest Anonymous Posted February 2, 2001 Share Posted February 2, 2001 I've been asking this question for a while but noone seems to know. So I went to the auto store, bought a plastic clutch alignment tool for a Chevy T5 and compared it to the Nissan T5 tool. -The chevy pilot shaft tip is actually slightly smaller and shorter than the Nissan, but it's clutch splines are fatter. -I haven't compared a Ford T5 shaft, maybe this weekend. - I suspect the Chevy T5 has a shorter overall main shaft lenght though, that would be unsurmountable. The solution once and for all would be for someone to measure the length of a Chevy and Nissan input shaft from tip to case. Clutch and pilot bushings could be modfied... Bryan Little The Datsun Z Garage Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 2, 2001 Share Posted February 2, 2001 Why not just buy a chebbie transmission instead of a nissan one? It would be lots ------------------ Morgan http://z31.com/~morgan/s30 http://carfiche.com Quote Link to comment Share on other sites More sharing options...
Guest Fast Frog Posted February 2, 2001 Share Posted February 2, 2001 Exactimundo!! (ditto Morgan's response) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 2, 2001 Share Posted February 2, 2001 It could well be made to fit. That still leaves quite a few mods and the trans still might not take the torque, the early T-5's didn't take more than about 230 Ft/Lbs, which is a mild small block at best. Not to discourage you, I hope you figure it out and hope it works fine for you, just not something I'd pursue given there are already kits to put the whole swap in. Lone [This message has been edited by lonehdrider (edited February 02, 2001).] Quote Link to comment Share on other sites More sharing options...
