Guest Aguyandaredhead Posted November 26, 2005 Share Posted November 26, 2005 If you have one that has not been installed yet is there anyway you could make a photocopy of the strut mount and maybe email it to me? I am going to have a few sets made out of steel and I just need the dim. so that I can get it all setup. I would prefer to have mine welded in instead of bolted. I just need you to be sure to check the copier and make sure it is not either enlarging or shrinking the picture. I am refering to the flat plate that the monoball mount gets bolted too. Thanks Jeff Quote Link to comment Share on other sites More sharing options...
Here comes trouble Posted November 28, 2005 Share Posted November 28, 2005 Jeff.. what are you using for the monoball housing. I am trying to source a pre-made housing for a com 10 monoball...here is my project thread http://forums.hybridz.org/showthread.php?t=106293 Quote Link to comment Share on other sites More sharing options...
Guest Aguyandaredhead Posted November 29, 2005 Share Posted November 29, 2005 I will be using the premade one that MM and GC sells I just want to weld the strut plate in instead of bolt it in. Most are made from aluminium and I want a steel plate. Jeff Quote Link to comment Share on other sites More sharing options...
