BWRex Posted December 1, 2005 Share Posted December 1, 2005 I've got a 71 240Z with 1.5 inch sectioned front struts w/ illuminas,200 lbs.front springs,strut spacers,TPI 350 JTR mounts.I'd like some opinions on setup.In the JTR manual,should I use the framerail/crossmember spacers,(page2-6)strut spacers(page16-4),and drill the raised holes in the crossmember(bumpsteer mod page 16-8 )with the lowered struts?or since I sectioned,can I get away with(or without)framerail spacers and/or strut spacers?I'd rather not drill new holes in the crossmember if I can help it.Any configurations,pics,or advise would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
wheelman Posted December 1, 2005 Share Posted December 1, 2005 You don't need the crossmember spacers, they only provide more hood clearance by lowering the engine relative to the body. They do not affect ride height in any way!!! I'll let others address the front control arm pivot point as they have much more knowledge and experience than myself with that issue. Try using the search function, the questions you asked have been addressed before and I'm sure you find all the information you need. Wheelman Quote Link to comment Share on other sites More sharing options...
fastzcars Posted December 1, 2005 Share Posted December 1, 2005 You should go to Pete Paraska's webpage. He's got alot of info on his install. lets see if I can put a hyperlink. Petes webpage Quote Link to comment Share on other sites More sharing options...
