oinojo Posted January 5, 2006 Share Posted January 5, 2006 sorry im just ranting because im so pissed... well anyways, i bought a clutch from autozone early october (stock clutch l28et/ beck arnley<---i think thats how you spell it) and after 580 miles its starting to slip bad. I dont see how it could be especially since its new. I installed everything as carefully as i can (no grease, threadlock...etc). Oh and to make things wierder, i havent even hooked up my turbo setup yet. I have my carbs on it to break it in. has anyone had issues with faulty clutches before? any from autozone? could i have a clutch not meant for my application? i have already talked to autozone about it and they keep telling me my warranty was already expired (90 days) even though i installed it 2 weeks ago. Also kept saying i installed it incorrectly. Perhaps i did, but im 98% sure i didnt. *sigh* end rant... Quote Link to comment Share on other sites More sharing options...
PeterZ Posted January 5, 2006 Share Posted January 5, 2006 Is the pushrod at the slave cylinder adjustable and is the release point in the pedal very high? You may have a too-tight adnustment. Did you change anything else like the release bearing/collar or pressure plate to go with the disc? Quote Link to comment Share on other sites More sharing options...
oinojo Posted January 6, 2006 Author Share Posted January 6, 2006 Is the pushrod at the slave cylinder adjustable and is the release point in the pedal very high? You may have a too-tight adnustment. Did you change anything else like the release bearing/collar or pressure plate to go with the disc? yeah the release point is fairly high on the clutch. I did replace everything (clutch set matched)... Quote Link to comment Share on other sites More sharing options...
