Kraker_Jax Posted January 6, 2006 Share Posted January 6, 2006 Purchases a RB25 from my friend and he's helping me get the tranny for it also. I was going to buy the motor mounts from 240Z_Master. Now I'm sure this is answered somewhere but I can't seem to find it. Which driveshaft do I need to use? Can I use a stock driveshaft out of an auto 260Z? Not sure if the auto and manual driveshafts are different, or maybe the driveshaft from a manual 280Z? I plan on also getting a 300ZX VLSD later on and believe those are a different length, a shortnose as opposed to the long nose, so I'll need a new driveshaft for that yes? Just trying to put everything in place, thanks for the responses! Quote Link to comment Share on other sites More sharing options...
S15 200sx owner Posted January 6, 2006 Share Posted January 6, 2006 Purchases a RB25 from my friend and he's helping me get the tranny for it also. I was going to buy the motor mounts from 240Z_Master. Now I'm sure this is answered somewhere but I can't seem to find it. Which driveshaft do I need to use? Can I use a stock driveshaft out of an auto 260Z? Not sure if the auto and manual driveshafts are different' date=' or maybe the driveshaft from a manual 280Z? I plan on also getting a 300ZX VLSD later on and believe those are a different length, a shortnose as opposed to the long nose, so I'll need a new driveshaft for that yes? Just trying to put everything in place, thanks for the responses![/quote'] I am doing a similar thing, and i plan on getting a custom one piece d/shaft built using the front piece to suit your trans and the rear piece to suit your diff and basically welding them to the correct lenght piece of tube in the middle, pretty straight forward for a shop that does this sort of thing. Quote Link to comment Share on other sites More sharing options...
Ed260Z Posted January 6, 2006 Share Posted January 6, 2006 No one makes a drive shaft specific to a RB Z swap. It will have to be a custom piece. You will need to bring your saft to a fabricator along with the appropraite flanges/yolks, and measurements. VLSD's can be a pain, you can use a 86-89 Cluch LSD. It's a long nose diff, so the install will be easier. And yes any time you change the distance between the tranny and the diff a new shaft will need to be made. Quote Link to comment Share on other sites More sharing options...
karay240 Posted January 7, 2006 Share Posted January 7, 2006 BTW, look for the N/A 300ZX diff (R200), the TT one is a R230, and you'll be seriously limited in the final gearing selection. FYI. and yes, since you are talking about changing both ends of the driveshaft, you will have to have a custom piece Kenny http://www.rbmotoring.com Quote Link to comment Share on other sites More sharing options...
