L28et STOCK HP
Z0wner
i put 168rwhp down on a stock L28ET on 77' ecu.
only had a JSK fuel rail and aeromotive fuel pressure regulator.
stock 280z fuel pump too.
mike
Are you using the stock dizzy with the advance disabled? Reeason why I'm asking is because the 77 ecu kinda through me off.
I don't know of the L28et rating but the L28e was rated with a 175 gross HP. I think it said 150 net hp.
it was disabled.
i used the 77 dizzy and we welded the bottom of it and made it work on the turbo shaft.
worked fine.
btw it was running 10.9 at WOT so it was way rich.
mike
