Guest ON3GO Posted January 24, 2006 Share Posted January 24, 2006 Got the Z running with the microtech today.. what a bitch! couldnt get spark for 4 days, i messed with something some how and all of a sudden i got spark haha. i think the dizzy timing is off so i gotta move it a tooth over or so. few coolent leaks, no oil leaks. Microtech guys.. what are you doing for the laptop software? i got the 1.1 beta ver from microtechs site but for some reason it wont work on my ECU. (LT8 btw). the handheld works fine, the laptop i can get a connection but cant do anything else. any ideas? car keeps flooding out like mad, 370cc injectors (all firing, none stuck open), walbro 255lph pump, 8an lines, a-1000 fuel pressure regulator, 2 fuel filters, jsk rail. i messed with the fuel pressure but still no matter what it floods. ill play with the pulse with but what do some of you guys have your settings on... FLYWHEEL!!!! i ordered a spec stage 4 clutch and spec turbo alum flywheel. NOW i had a turbo clutch and flywheel in the Z before, i have the turbo starter too. NOW the starter only grabs sometimes, spins, then grabs then CRACKKKKKKKKKKKK, then spins. i SO hope i dont have a n/a flywheel with turbo clutch. but what if i do? can i just use a n/a starter and be okay? with this not work? i searched but didnt really find anything with using a n/a flywheel (which i hope i dont have) and turbo clutch and starter. besides that nitrous is on its way and i hope to have it 100% done by friday! mike Quote Link to comment Share on other sites More sharing options...
David NA->FI Posted January 24, 2006 Share Posted January 24, 2006 I can vouch for this accomplishment. He did it all on his own I was there when we were starting it up. Kinda lumpy but it did run at a set RPM....Hopefully he'll figure the rest out soon enough. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted January 24, 2006 Share Posted January 24, 2006 anybody.. before i pull my brains out from searching so damn much Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted January 24, 2006 Share Posted January 24, 2006 hmm i think i figured out the flywheel problem tell me if you guys think this is right. the plate between the trannt and engine is powdercoated.. nice and thick too. i think since its thicker the starter isnt touching the flywheel all the way. i mean if it is a 225mm flywheel then wouldnt the starter not even touch it at all? any ideas? mike Quote Link to comment Share on other sites More sharing options...
Zraced... Posted January 24, 2006 Share Posted January 24, 2006 You are probably getting way to much fuel from the injectors...it is probably set up for the factory setting. I had the same problem with my 555cc injectors...if you go to the setting for Mixtrm on screen 30 you will have to reduce that value, which will perform a blanket reduction over the entire fuel map. The motor should start to smooth out as the mixture leans out. Got the Z running with the microtech today.. what a bitch!couldnt get spark for 4 days' date=' i messed with something some how and all of a sudden i got spark haha. i think the dizzy timing is off so i gotta move it a tooth over or so. few coolent leaks, no oil leaks. Microtech guys.. what are you doing for the laptop software? i got the 1.1 beta ver from microtechs site but for some reason it wont work on my ECU. (LT8 btw). the handheld works fine, the laptop i can get a connection but cant do anything else. any ideas? car keeps flooding out like mad, 370cc injectors (all firing, none stuck open), walbro 255lph pump, 8an lines, a-1000 fuel pressure regulator, 2 fuel filters, jsk rail. i messed with the fuel pressure but still no matter what it floods. ill play with the pulse with but what do some of you guys have your settings on... FLYWHEEL!!!! i ordered a spec stage 4 clutch and spec turbo alum flywheel. NOW i had a turbo clutch and flywheel in the Z before, i have the turbo starter too. NOW the starter only grabs sometimes, spins, then grabs then CRACKKKKKKKKKKKK, then spins. i SO hope i dont have a n/a flywheel with turbo clutch. but what if i do? can i just use a n/a starter and be okay? with this not work? i searched but didnt really find anything with using a n/a flywheel (which i hope i dont have) and turbo clutch and starter. besides that nitrous is on its way and i hope to have it 100% done by friday! mike[/quote'] Quote Link to comment Share on other sites More sharing options...
Zraced... Posted January 24, 2006 Share Posted January 24, 2006 As for the communication...do you have the black interface module that the serial cable plugs into? This I think is how it communicates with the Microtech through the laptop. Quote Link to comment Share on other sites More sharing options...
Zraced... Posted January 24, 2006 Share Posted January 24, 2006 on this web site it is the white plug adapter next to the CD http://www.microtech-efi.com/product/14.html Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted January 24, 2006 Share Posted January 24, 2006 no i just downloaded the beta ver and bought a USB to serial port adapater and did it that way. will this way not work? mike Quote Link to comment Share on other sites More sharing options...
Zraced... Posted January 24, 2006 Share Posted January 24, 2006 I think you need it to communicate...If you have the hand controller you must be able to access the same settings...you may have to set down with it for a while to get used to it...to bad they don't have a simulator program. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted January 24, 2006 Share Posted January 24, 2006 ya the handheld is sorta a bitch but its getting more and more easier to use. i guess ill just spring for the 150 bucks.. mike Quote Link to comment Share on other sites More sharing options...
