msd and alternator troubles
Guest storyteller803
I've posted several times on zcar.com and had some success. Just can't get this final problem worked out. MSD 6a, 8920 tac adapter, spiral wires, zx distributor. large gauge black and red to battery. Switch red to switch in cabin.
Here's the problem. Car runs fine when plug on alternator is unplugged, voltage regulator, I believe. But no charge. Stumbles and misses when plugged in. Tech support says it sounds like interference in mag. sensor wire. Routed wire in front of radiator. coil wire in front of charcoal canister pipes to intake. What else can I do? Anyone else have this issue???
