Turbo280Z Posted February 3, 2006 Share Posted February 3, 2006 ok heres what happend on my l28et 280z one of my wires was loose from the harness to my dizzy. so i unpluged the harness and when i went to unplug it from the main harness it broke a couple wires. and i cant splice them together cuz the colors dont match. so heres my question.... the 4 wires coming from the harness (b,bw,gb,gy) which spots do they go to on the dizzy? will anyone help me? plzzzz lol Quote Link to comment Share on other sites More sharing options...
Turbo280Z Posted February 3, 2006 Author Share Posted February 3, 2006 haha i found the diagram its... dizzy side----harness side red----------b/w white--------g/b green--------g/y black--------black hope it helps someone else Quote Link to comment Share on other sites More sharing options...
Turbo280Z Posted February 4, 2006 Author Share Posted February 4, 2006 ok after i wired it back in the car only sparks when it wants to. before it was running pretty good. if i pick the dizzy u and spin it it sparks but when i crank it it doesnt sometimes. i made sure the connections were good and it sparks when it wants to. the harness from the main harness to the dizzy was pretty messed up so i wired in new wires and now thats what happens. could my CAS be goin bad? or should i jus replace the harness? does anyone know if a z31 CAS will work in the 280 dizzy? has anyone tried? Quote Link to comment Share on other sites More sharing options...
Zraced... Posted February 12, 2006 Share Posted February 12, 2006 ok after i wired it back in the car only sparks when it wants to. before it was running pretty good. if i pick the dizzy u and spin it it sparks but when i crank it it doesnt sometimes. i made sure the connections were good and it sparks when it wants to. the harness from the main harness to the dizzy was pretty messed up so i wired in new wires and now thats what happens. could my CAS be goin bad? or should i jus replace the harness? does anyone know if a z31 CAS will work in the 280 dizzy? has anyone tried? The only difference are the disks...so if you swap them you should be OK. Quote Link to comment Share on other sites More sharing options...
Turbo280Z Posted February 12, 2006 Author Share Posted February 12, 2006 well if the z31 cas disk is sposed to be a upgrade for the 280 i could jus but both in then right? Quote Link to comment Share on other sites More sharing options...
Zraced... Posted February 12, 2006 Share Posted February 12, 2006 The sensor is the same the disk in the z31 has a larger slot for the TDC reference...the sensor can be swapped from either dizzy. Quote Link to comment Share on other sites More sharing options...
Turbo280Z Posted February 12, 2006 Author Share Posted February 12, 2006 yea i know but the disc is sposed to be a upgrade for the 280 or so ive herd Quote Link to comment Share on other sites More sharing options...
TheNeedForZ Posted February 12, 2006 Share Posted February 12, 2006 yea i know but the disc is sposed to be a upgrade for the 280 or so ive herd People put Z31 disk in their L28et dizzy because they upgrade to Z31T ECU or a similar ECU that is reprogrammed. The upgraded ECU requires Z31 disk (which has one wider slot at TDC) to run. The real upgrade is the ECU; The Z31 disk is just a requirement to the upgrade. Can you run a Z31 disk with L28ET ECU? I too am searching for that answer. If you successfully ran your L28ET with a Z31 dizzy disk, please let me know. Thanks Quote Link to comment Share on other sites More sharing options...
Turbo280Z Posted February 12, 2006 Author Share Posted February 12, 2006 ok ill prolly test it in the morning. ill post back if it works or not Quote Link to comment Share on other sites More sharing options...
