Silent Posted February 6, 2006 Share Posted February 6, 2006 yea that same question centerforce dual friction exedy series act {i think they have em for the s30 cars} has to handle 400 ft lbs what would YOU put in your car to handle 400 ft lbs {ie turbo, nitrous guys} Quote Link to comment Share on other sites More sharing options...
Pyro Posted February 6, 2006 Share Posted February 6, 2006 SPEC stage 2 or 3. Stage 2 is much easier to drive on the street as compared to the stage 3 which chatters on slow take offs. Stage 2 is a kevlar disk, rated at 450 lb-lbs, and requires a few hundred mile break in. Stage 3 is a ceramic disk and is rated over 500 ft lbs. The clutches are at NipponPower.com. Quote Link to comment Share on other sites More sharing options...
Silent Posted February 6, 2006 Author Share Posted February 6, 2006 SPEC stage 2 or 3. Stage 2 is much easier to drive on the street as compared to the stage 3 which chatters on slow take offs. Stage 2 is a kevlar disk' date=' rated at 450 lb-lbs, and requires a few hundred mile break in. Stage 3 is a ceramic disk and is rated over 500 ft lbs. The clutches are at NipponPower.com.[/quote'] the reason i was goin with those is i can get them through my work at silly discounts. but i'll check those out as well Quote Link to comment Share on other sites More sharing options...
Pyro Posted February 7, 2006 Share Posted February 7, 2006 Oh. I see. I'm not sure how accurate the torque specs are for clutches, but SPEC seems to be about the highest. I would also upgrade to a 240mm (I forgot to mention that). Quote Link to comment Share on other sites More sharing options...
510six Posted February 7, 2006 Share Posted February 7, 2006 http://www.10000rpm.com I am using one of their twin disc kevlar drag race clutches.You might want to talk to them for what would work best for your application. http://pg.photos.yahoo.com/ph/sss510six/detail?.dir=15c7&.dnm=55c7.jpg&.src=ph Quote Link to comment Share on other sites More sharing options...
Silent Posted February 7, 2006 Author Share Posted February 7, 2006 for what i want to do, a act can do it, while handling 462 ft lbs. and i can get the kit for under 200 bucks through my work there is a thing of being cheap, but being cheap and getting good stuff. dunno, more or less going for opinions on what people thought about those three Quote Link to comment Share on other sites More sharing options...
