clutches
Silent
SPEC stage 2 or 3. Stage 2 is much easier to drive on the street as compared to the stage 3 which chatters on slow take offs. Stage 2 is a kevlar disk, rated at 450 lb-lbs, and requires a few hundred mile break in. Stage 3 is a ceramic disk and is rated over 500 ft lbs.
The clutches are at NipponPower.com.
SPEC stage 2 or 3. Stage 2 is much easier to drive on the street as compared to the stage 3 which chatters on slow take offs. Stage 2 is a kevlar disk' date=' rated at 450 lb-lbs, and requires a few hundred mile break in. Stage 3 is a ceramic disk and is rated over 500 ft lbs.
The clutches are at NipponPower.com.[/quote']
the reason i was goin with those is i can get them through my work at silly discounts. but i'll check those out as well
for what i want to do, a act can do it, while handling 462 ft lbs. and i can get the kit for under 200 bucks through my work
there is a thing of being cheap, but being cheap and getting good stuff.
dunno, more or less going for opinions on what people thought about those three
