Where should I get solid sway bar bushings???
Guest mattrp
Guest mattrp
I have a 72 240z which I fitted with a rear sway bar last weekend. The bar in the rear is hard mounted and makes the car drive like a slalom car. I am looking to increase the front ent stiffness to get things closer to normal, with no lean. Are there any larger compatible sway bars for the front, or where can I get solid sway bar bushings for the front to increase the stiffness.
Matt
72 500Z
