mobythevan Posted February 23, 2006 Share Posted February 23, 2006 Mikes Projects: 1. Coming up next month Mike and I will be firing up a 2004 hemi for a street rod project that his dad owns. Looks like it will get fired up on the factory ECU and then fuel and spark will be converted over the MSnS. Should be interesting. He has been doing all the research on the engine, it does not have MDS. It does have 2 plugs per cylinder which would require an interesting coil configuration. The factory ECU also runs the auto tranny. 2. Mike also has turbos going on his sbc that is already squirted and he has an LT1 engine for swap into a 56 wagon. The LT1 will get MSnS hopefully in June. My Projects: 1. I will also be installing MSnS on the Talon in March. The two projects should help bring me back up to speed on the 029 code versions of MSnS. I ordered my kit from Jerry yesterday. I am going to build a harness adapter so the megasquirt plugs directly into the factory harness at the ECU plugs and does not use a realy board, should turn out real clean. 2. The 34 pontiac with 454 is still moving along. I am at the point of attaching the camaro subframe, then I can set the engine in and start hooking up the MSnS on it. So even though I am zcar-less right now there is no shortage of fun projects going on. I still want to experiment with water injection and knock detection on the Talon using MSnS. I'll keep you guys updated as each one comes online, should be a fun summer. Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted February 23, 2006 Administrators Share Posted February 23, 2006 Moby, We are all looking forward to reading much more about these MSnS projects. Are any of them going DIS of any sort? I’m sure we’ll have a lot more questions…. Thanks for the update. Our MSnS-E Z car project.... http://www.msefi.com/viewtopic.php?t=15436 Quote Link to comment Share on other sites More sharing options...
mobythevan Posted February 23, 2006 Author Share Posted February 23, 2006 Actually all of them will be DIS. The talon of course is easy, its already set up for DIS with 2 coils, each running 2 cylinders. I bought an EDIS wheel that fits my supercharger crank pulley for the 454. We will use the same kind of EDIS wheel for the turbo sbc, and the LT1. The Hemi, who knows yet. Have to see what kind of factory trigger setup it uses. That will will definitely be the fun/involved project. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted February 24, 2006 Share Posted February 24, 2006 Bryan let me know when your going to start the swap... I can drive up and attempt to help ya guys out, and learn... I can't believe Mike is still workn on that TT project using those Nissan T3's right?? Quote Link to comment Share on other sites More sharing options...
mobythevan Posted February 24, 2006 Author Share Posted February 24, 2006 Yeah, he has two 60/63 turbos to put on there. He started having a new house built this winter. It is almost dried in now. That has really slowed down his projects. I'll let you know when the fun starts. Quote Link to comment Share on other sites More sharing options...
