Modifing titanium wrist pins
TheNeedForZ
I have a chance to get a set of used titanium piston pins(8) and I am contemplating modifying them for my L28ET.
The funny thing is, the pins are really short for the engine they were designed for (I think they are for Chevy or Ford?, see spec below) They are 57.15mm long so I dunno if it's ok to run a pin that short in a street vehicle.
Stock L series pin
21mm dia.
72.06mm long
4mm wall thickness
120 gram
used titanium pin
23.57mm dia.
57.15mm long
5mm wall thickness
77 grams
Ti pin after modified to fit L28ET
21mm dia.
57.15mm long
3.715mm wall thickness
70 gram? guesstimated
What do you think? If the short pins were used to run a larger bore Chevy or Ford, it is going to be ok to use them in a smaller bore Datsun L(gonna use 87mm)? My plan is to sand off the casidium coating, rough turn them on my home lathe and take the pins to a precision machine shop to turned to correct size. Then I'll have them coated again with either the original casidium coating or nitriding.
Thanks in advance for well informed inputs.
Every party needs a pooper...
IMHO- a really bad idea, save your money. Even regular wrist pins are hard, and IIRC titanium has a rep for being almost impossible to machine. (If there is sufficient meat in the rod end and piston, perhaps they could be made to fit the pins)?
This response not guaranteed to be well informed..:icon45:
