TheNeedForZ Posted March 3, 2006 Share Posted March 3, 2006 I want to produce a thread about the internal dimensions of L series pistons. What I do is I cut them up and post thickness measurement taken in different areas. I will cut each piston twice. The first cut plane is a vertical one right thru the centerline, perpendicular to the wrist pins. The second cut plane is also a vertical one thru the centerline but parallel to the pin bore axis. I already cut up a L26 piston, I am looking for L24 piston (unless they are identical to 260Z ones other than bore size) L28 dished (NA and Turbo, identical other than bore size?) L28 flat top Suggestions? Quote Link to comment Share on other sites More sharing options...
