Guest needwaymorespeed Posted July 11, 2000 Share Posted July 11, 2000 Ive noticed that alot of people are wanting to convert over to the cv shaft halfshafts on the rear and retain there larger stub axles that the 74-78 z cars have instead of installing the smaller 240 z stub axle and not having to install a custom set of adapters. are the 280 z stub axles realy that superior to the 240?? Why not take the 240 z stub axles and companion flanges-have them magnafluxed-if ok have them heat treated for added strength- Has anyone heat treated these pieces?? the cost is real reasonable 20 -50$$ depending on the process selected-first have to have a metalurgical analysis made to determine the metal used for these components -the metal will determine which proces is the best to use . What do you guys think?? Curtis Quote Link to comment Share on other sites More sharing options...
Guest Jason Posted July 11, 2000 Share Posted July 11, 2000 You could also try cryo-treatment. Supposedly does a good job of tempering steel at only $7/lb. -Jason Quote Link to comment Share on other sites More sharing options...
