badjuju Posted March 19, 2006 Share Posted March 19, 2006 I need to jumper the FIDLE relay on my relay board, but I don't know which terminal is which. Could someone take a quick minute and type up which ones I should jumper to use it for triggering? Quote Link to comment Share on other sites More sharing options...
mobythevan Posted March 20, 2006 Share Posted March 20, 2006 Ok, this may be one ugly picture, but it has served its purpose for this very question many times. Quote Link to comment Share on other sites More sharing options...
badjuju Posted March 27, 2006 Author Share Posted March 27, 2006 I just noticed I have 3 active threads on the first page of this thread section, and decided to just reuse this one... When I open MegaTune, i get an error: WARNING:MSnS-extra.ini:0202 - Constant definition for "ignmode" has too many parameters 11, 10 expected. I've searched on this on both hybridz and msefi.com, but i can't seem to find how to remedy this... any knowers out there? tia alec denson Quote Link to comment Share on other sites More sharing options...
mobythevan Posted March 27, 2006 Share Posted March 27, 2006 sounds like the wrong version of msns.extra.ini file for the version of megatune you have installed. You always have to copy the .ini file into the megatune directory (don't remeber which directory off hand). Quote Link to comment Share on other sites More sharing options...
badjuju Posted March 28, 2006 Author Share Posted March 28, 2006 I'm getting ~280 degrees F for my coolant reading, though the engine is cold and hasn't even been started up with ms yet. i switched the +and- of the sensor and it changed to 271... does the wiring matter, and why would I be getting these readings? Quote Link to comment Share on other sites More sharing options...
mobythevan Posted March 28, 2006 Share Posted March 28, 2006 you have to calibrate if you use the nissan CHTS. The calibration values are in the sticky and you use easytherm. Are you using the CHTS or GM coolant sensor? Quote Link to comment Share on other sites More sharing options...
badjuju Posted March 28, 2006 Author Share Posted March 28, 2006 bought a GM closed element for coolant and an open element for AIT, but only the coolant is giving weird measurements. sounds like a bad sensor then? Quote Link to comment Share on other sites More sharing options...
mobythevan Posted March 28, 2006 Share Posted March 28, 2006 I wouldn't expect the sensor to be bad if you bought a new one. You can measure the resistance across the sensor at room temp and look up the sensor curve in the megamanual to see if the resistance reading is correct. Did you build the megasquirt yourself or buy a pre-assembled one? Wrong value resistor installed in the coolant sensor circuit?? Quote Link to comment Share on other sites More sharing options...
badjuju Posted March 28, 2006 Author Share Posted March 28, 2006 bought a preassembled, diyautotune.com Quote Link to comment Share on other sites More sharing options...
