Need help! 82zx turbo EFI sensors
Wide260z
Alright, so some of these sensors on the 280zx EFI harness are confusing, do i need them, or what do they do?
Cylinder head temp sensor - is it needed?
EFI relay - what exactly does it do??
Thermal transmitter - Sounds like a detonation switch for a bomb.
Air regulator sensor - Have not found this
Pump control modulator - which pump is this for? Old Smog pump, or fuel pump? Should i just not worry about it?
I am trying to get the EFI harness together and get everything that is needed to put it in my 74 260.
You need at least the chts and the efi relay. won't run without them.
The fuel pump modulator isn't needed either, i'm not running one.
The other two aren't really needed especially being if Florida. Mainly for cold start up I believe.
