PapaCreech Posted April 14, 2006 Share Posted April 14, 2006 how hard to take my 280z 2+2 to the 175-200 RWHP range? and how expensive anyone know off hand? any guides or step by steps? thanks ron Quote Link to comment Share on other sites More sharing options...
Mack Posted April 14, 2006 Share Posted April 14, 2006 your best bet is a turbo motor. buuuut, it could be done with megasquirt, a lonewolf manifold, a header, 2.5" exhaust and some more compression. amybe a regrind on your camshaft. Id probably figure on $1500, if you do all the actual WORK yourself. Quote Link to comment Share on other sites More sharing options...
2802NR Posted April 17, 2006 Share Posted April 17, 2006 Turbo Isn't nessisary. Get a junkyard ZX motor, (81-83 P79) put your N47 head on it with a 1mm head gasket and a "stage 3" or higher cam. then get a header & 2.5 exhaust. Throw in a set of SU carbs and you shoud be at or above 175. If you keep the fuel injection it may take a little more depending on your elevation. Just for an example: I did that only I re-built mine with flattop's instead of using the junkyard motor and I used a standard HG. I was at 160hp on stock injection @ 4300 ft. elevation. I spent close to $2000 but the junkyard route would be cheaper Quote Link to comment Share on other sites More sharing options...
